WS-Ссылка не открывается | ☑ | ||
На стороне добра
07.08.12
Всем привет!
Не могу получить WS-Ссылку вот определение http://demo.b2b-center.ru/market/remote.html?wsdl <?xml version="1.0" encoding="ISO-8859-1" ?> - <definitions xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="urn:ws" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" xmlns="http://schemas.xmlsoap.org/wsdl/" targetNamespace="urn:ws"> - <types> - <xsd:schema elementFormDefault="qualified" targetNamespace="urn:ws"> <xsd:import namespace="http://schemas.xmlsoap.org/soap/encoding/" /> <xsd:import namespace="http://schemas.xmlsoap.org/wsdl/" /> - <xsd:complexType name="auth_info"> - <xsd:sequence> <xsd:element name="login" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="password" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="response_status"> - <xsd:sequence> <xsd:element name="error_code" type="xsd:integer" minOccurs="1" maxOccurs="1" /> <xsd:element name="error_message" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="message" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_status"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_integer"> - <xsd:sequence> <xsd:element name="value" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="service_row"> - <xsd:sequence> <xsd:element name="id" type="xsd:integer" minOccurs="1" maxOccurs="1" /> <xsd:element name="name" type="xsd:string" minOccurs="1" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_services"> - <xsd:sequence> <xsd:element name="service" type="tns:service_row" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="firm_info"> - <xsd:sequence> <xsd:element name="date_lastedit" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="org_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="org_name_short" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="code_okpo" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_inn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ogrn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ogrn_given" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ogrn_date_given" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_kpp" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_bik" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_r_account" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_c_account" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_comments" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="jury_address" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="post_address" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="fact_address" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="site_url" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="certification" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="org_details" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_details" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="country" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_firm_info"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="firm_info" type="tns:firm_info" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="department_data"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="description" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="status" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="type" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_modified" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_department_data"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="department_data" type="tns:department_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="user_data"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="login" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="password" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="lastname" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="firstname" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="midname" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="email" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="phone" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="fax" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="document" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="department_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="position" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="status" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="permissions" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ext_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_user_data"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="user_data" type="tns:user_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="okdp_row"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="parent_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_modified" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_okdp_rows"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="okdp_rows" type="tns:okdp_row" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_ids"> - <xsd:sequence> <xsd:element name="string" type="xsd:string" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_array_of_ids"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="ids" type="xsd:string" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="associative_row"> - <xsd:sequence> <xsd:element name="name" type="xsd:string" minOccurs="1" maxOccurs="1" /> <xsd:element name="value" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="associative_array"> - <xsd:sequence> <xsd:element name="row" type="tns:associative_row" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_associative_array"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="array" type="tns:associative_array" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="file"> - <xsd:sequence> <xsd:element name="title" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="description" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="name" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_files"> - <xsd:sequence> <xsd:element name="file" type="tns:file" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_doc"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="doc" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_file"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="file_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="address_data"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="country" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="okato_region" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="address" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="comment" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="lat" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="lng" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="status" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_address_data"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="address_data" type="tns:address_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="firm_request"> - <xsd:sequence> <xsd:element name="ogrn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="inn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="okpo" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_kpp" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="firm_data"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="org_name_short" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="org_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ogrn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="inn" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="okpo" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="bank_kpp" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_find_firm"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="firm_data" type="tns:firm_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_firm_data"> - <xsd:sequence> <xsd:element name="firm_data" type="tns:firm_data" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="firm_tender"> - <xsd:sequence> <xsd:element name="tender_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="organizer_firm" type="tns:firm_data" minOccurs="0" maxOccurs="1" /> <xsd:element name="common_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_begin" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_unsealing" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="opened" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="winners_firms" type="tns:array_of_firm_data" minOccurs="0" maxOccurs="1" /> <xsd:element name="participants_count" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="offers_count" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_offer" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_firm_tenders"> - <xsd:sequence> <xsd:element name="firm_tender" type="tns:firm_tender" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_firm_tenders"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="firm_data" type="tns:firm_data" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_tenders" type="tns:array_of_firm_tenders" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_modified_purchases"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="modified_purchases" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="ret_register_firm"> - <xsd:sequence> <xsd:element name="status" type="tns:response_status" minOccurs="1" maxOccurs="1" /> <xsd:element name="register_result" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> <xsd:complexType name="RemoteMarket.getServicesRequestType" /> - <xsd:complexType name="RemoteMarket.getServicesResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:array_of_services" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmInfoRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmInfoResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_firm_info" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmPropertiesRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="prop_keys" type="tns:array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmPropertiesResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_associative_array" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getClassifierRowsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="ids" type="tns:array_of_ids" minOccurs="0" maxOccurs="1" /> <xsd:element name="is_parent" type="xsd:boolean" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getClassifierRowsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_okdp_rows" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedClassifierRowsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_from" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedClassifierRowsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_okdp_rows" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateUserRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="data" type="tns:user_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateUserResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getUserRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="user_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getUserResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_user_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteUserRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="user_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteUserResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_status" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getUsersIdsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getUsersIdsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateDepartmentRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="data" type="tns:department_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateDepartmentResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getDepartmentRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="department_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getDepartmentResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_department_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteDepartmentRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="department_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteDepartmentResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_status" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getDepartmentsIdsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getDepartmentsIdsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getHierarchyFirmsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getHierarchyFirmsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateAddressRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="data" type="tns:address_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.updateAddressResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="address_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_address_data" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteAddressRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="address_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.deleteAddressResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_status" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressesIdsRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressesIdsResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressIdByOkatoRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="country" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="okato" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="address" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getAddressIdByOkatoResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.findFirmRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_request" type="tns:firm_request" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.findFirmResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_find_firm" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.findFirmTendersRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="find_options" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.findFirmTendersResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_firm_tenders" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmClassifierRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_id" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="type" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getFirmClassifierResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_array_of_ids" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedPurchasesRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="modified_after" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="skip" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="count" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedPurchasesResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_modified_purchases" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedPurchases223fzRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="iframe" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="modified_after" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="skip" type="xsd:integer" minOccurs="0" maxOccurs="1" /> <xsd:element name="count" type="xsd:integer" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.getModifiedPurchases223fzResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_modified_purchases" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.registerFirmRequestType"> - <xsd:sequence> <xsd:element name="auth" type="tns:auth_info" minOccurs="0" maxOccurs="1" /> <xsd:element name="firm_data" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="RemoteMarket.registerFirmResponseType"> - <xsd:sequence> <xsd:element name="return" type="tns:ret_register_firm" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="lot"> - <xsd:sequence> <xsd:element name="lot_id" type="xsd:integer" minOccurs="1" maxOccurs="1" /> <xsd:element name="lot_name" type="xsd:string" minOccurs="1" maxOccurs="1" /> <xsd:element name="classifier_ids" type="xsd:string" minOccurs="1" maxOccurs="1" /> <xsd:element name="customer" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="ext_id" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="array_of_lot"> - <xsd:sequence> <xsd:element name="lot" type="tns:lot" minOccurs="0" maxOccurs="unbounded" /> </xsd:sequence> </xsd:complexType> - <xsd:complexType name="tender_data"> - <xsd:sequence> <xsd:element name="id" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="open" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="common_name" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="lots" type="tns:array_of_lot" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_job_begin" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_job_end" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_unsealing" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="date_unsealing_comment" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="committee" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="participants" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element |
На стороне добра
07.08.12
http://www.w3.org/2001/XMLSchema прописана. Что ему еще надо?
Создаю WSПрокси, пишет что веб-сервис не найден |
На стороне добра
07.08.12
Когда создаю WS-ссылку и прописываю URL источника, то пишет "Не верный формат"
alex-pro
07.08.12
У меня тоже (2)
alex-pro
07.08.12
А че за сервис-то такой?
На стороне добра
07.08.12
Разработчик веб-сервиса говорит у них через 1С клиенты уже работали
На стороне добра
07.08.12
электронные торги
На стороне добра
07.08.12
Где можно прогнать XML-схему, чтобы узнать какие есть в ней ошибки?
На стороне добра
08.08.12
up
На стороне добра
09.08.12
ап
zladenuw
09.08.12
как именно ты пишешь.
Определения = Новый WSОпределения("http://demo.b2b-center.ru/market/remote.html?wsdl"); Так ошибки нету. схему получает. |
На стороне добра
09.08.12
Во! Заработало! Я так тоже пробывал раньше не работало.
Спасибо тебе (10) |
На стороне добра
09.08.12
Кто знает как вызывать метод с именем "RemoteTender.create" ? Ну то есть имя метода, которое содержит "точку". Конфигуратор естественно воспринимает сначало "RemoteTender" и ругается, что такого метода нет.
На стороне добра
09.08.12
В WSИнтерфейс.Операиции ничего нет
На стороне добра
09.08.12
WSИнтерфейс.Операции
